1 - 20 of 86 Posts
CNC Machine Shop
Here is my newest arm!!
Same 1 1/4" Thick milled arm as my other HD tie in kit arms, now avail with 6 bolt holes and keyway machined for SOLID Knuckles.
ARMS CANNOT BE PRE-DRILLED FOR TIE IN BOLT. ALL FACTORY KNUCKLES ARE SLIGHTLY DIFFERENT. YOU WILL NEED TO INSTALL THE ARM AND THE TIE IN BOLT LIKE IN THE PICTURE TO MARK THE LOCATION ON THE BOTTOM OF THE ARM AND THEN REMOVE AND DRILL.
I CAN DRILL LINKAGE HOLES FOR YOU. FOR HEIMS OR GM TRE.
You can find and order them here.
Four Wheel Supply - Pair of Dana 60 High Steer arms for SOLID Knuckles with tie in kit
Installing mine this weekend; very nice product btw. What are you recommending the torque spec for the 6 studs?
CNC Machine Shop
Discussion Starter #10
90 Ft lbs on most all 1/2" Grade 8 Hardware will be sufficient.
When you get them installed post up a pic here, if you don't mind.
Thanks
Thanks
Thank you. Will do.
How about the torque on the 3/4" bolt connecting the high steer arm to the knuckle?
Reid Knuckles
Do you offer an arm like this that will work with a D60 Reid racing knuckle? needs to have the tie in to the lower tie-rod hole as well. any info would be great Thank you
CNC Machine Shop
Discussion Starter #18
1 - 20 of 86 Posts
