1 - 20 of 159 Posts
CNC Machine Shop
Here is a new arm I just finished. CNC Plasma burnt from 3/4" A36 Steel. Then CNC Machined on a FAdal Vertical macining center all here in house. Kit will include 2 arms, all neccesary springless conversion hardware, 2- 10" 5/8" Bolts 2-pcs of 1" OD DOM tubing and 2 NyLock nuts. This will allow you to add another mounting location on your D60 Knuckle to add even more strength. Going to leave hole undrilled for 5/8 bolt just because all knucles will be different, so location will also be different. As always FREE SHIPPING. Kit will run ya $135. And you can add a stud/nut kit for $20
Order arms here: https://www.fourwheelsupply.net/products/pair-dana-60-high-steer-arms-w-knuckle-tie-in-kit
ARMS CANNOT BE PRE-DRILLED FOR TIE IN BOLT. ALL FACTORY KNUCKLES ARE SLIGHTLY DIFFERENT. YOU WILL NEED TO INSTALL THE ARM AND THE TIE IN BOLT LIKE IN THE PICTURE TO MARK THE LOCATION ON THE BOTTOM OF THE ARM AND THEN REMOVE AND DRILL.
I CAN DRILL LINKAGE HOLES FOR YOU. FOR HEIMS OR GM TRE.
CNC Machine Shop
Discussion Starter #8
Top Section where the tie in bolt will be milled just enough to give the nut a flat spot to sit. It will not be possible to mill the entire top of the arm and bottom for the angle correction because the material is not thick enough. After I get these done I plan on adding a thicker arm like my HD arms that will be milled top and bottom. And hopefully pics will come later today. Thanks
Is it possible to order these with 3/4 hardware...or even without the 5/8 hardware? Will they take a 3/4 bolt? Or would it just be better to order your thick milled and go from there?
CNC Machine Shop
Discussion Starter #17
When i made these knuckles i made them on chevy knuckles. I would have never imagined there were that much difference, Im gonna add more material to that area next round. and make an option for 3/4 hardware
You will have me sold with that option:D
Any idea when the next round will be? I'm in the market for a set of arms when they have the 3/4" hardware.
He said it would be a while before he runs anymore. If you change your mind i have a set of the 5/8 ones ill sell cheap because I am going to have to go with the Artec arms. Had I known they didnt play nicely with the ford knuckles I wouldnt have went this route
1 - 20 of 159 Posts
