141 - 159 of 159 Posts
CNC Machine Shop
Discussion Starter #150
How much are they?
From post #1
"Here is a new arm I just finished. CNC Plasma burnt from 3/4" A36 Steel. Then CNC Machined on a FAdal Vertical macining center all here in house. Kit will include 2 arms, all neccesary springless conversion hardware, 2- 10" 5/8" Bolts 2-pcs of 1" OD DOM tubing and 2 NyLock nuts. This will allow you to add another mounting location on your D60 Knuckle to add even more strength. Going to leave hole undrilled for 5/8 bolt just because all knucles will be different, so location will also be different. As always FREE SHIPPING. Kit will run ya $135. And you can add a stud/nut kit for $20
Order arms here: https://www.fourwheelsupply.net/prod...kle-tie-in-kit
ARMS CANNOT BE PRE-DRILLED FOR TIE IN BOLT. ALL FACTORY KNUCKLES ARE SLIGHTLY DIFFERENT. YOU WILL NEED TO INSTALL THE ARM AND THE TIE IN BOLT LIKE IN THE PICTURE TO MARK THE LOCATION ON THE BOTTOM OF THE ARM AND THEN REMOVE AND DRILL.
I CAN DRILL LINKAGE HOLES FOR YOU. FOR HEIMS OR GM TRE."
Ordered a pair and specified 1979 Ford D60 Knuckles in the checkout, that info didn't show up in the confirm so I'm putting it here as backup. Will also PM.
