What parts are you using exactly, looks like gm caliper brackets. What is the brand of spindle(gm? or ford?) And those are definitely ford hubs, what is the axle stubs? If the stubs are gm and the spindle is gm, then the hubs wont work unless you modify it to work, which doesnt look like you understand how on that part yet
Simply turning the hubs down doesnt make the gm parts work together with ford parts.
If you have ford knukles and spindle, you could take a dremel and follow the original splines and cut your way into the stub and shorten it as a last measure if you cant come up with correct parts, and its not so bad to do, you would cutyourself a new c-clip groove also at the end.
