1 - 10 of 10 Posts
i was wondering how much a front dana 60 is worth
Dana 60 Front Axle from a 1980 k30 (1 ton)
heres are the rest of the specs:
it is open. no locker.
4.88s gears
recently installed with master kit
crossover steering
ford rotors dual piston calipers and pads
new brake lines
comes with a drive shaft with 1310 ujoints
hub to hub COMPLETE hubs turn like butter
Is turning like butter anything like churning butter? I'm here to tell you that is hard work. I'll give $75 and some home made butter for the axle.
It would be worth more if it had the chevy brakes instead of the junk fords.
X2 put the chevy knuckles back on and run the chevy outers, jason.
the fords brakes are way better then the chev brakes. (like everything else ford did is better then chev)
unless you want to run 15" rims
but irocs are available in 17" and so are beadlocks
If you say so. The ford knuckles are much weaker than the chevy knuckles. Ford has twin piston calipers which take up a ton of room and will almost rule out all 15 and 16 inch wheels.
1 - 10 of 10 Posts
