Dana 60 or 14 bolt disc brake kit $315 shipped
260256 Views 990 Replies 308 Participants Last post by  GubNi
2
This thread was started in 2009 but I am still selling these in 2018 and will in 2019 also. My price is the same, so why start a new thread?
To place an order go to my website --> www.lugnut4x4.com
Don't stop for less!
I guarantee the best price. Shop around. If you find a better price send me a message with a link and I will beat it!
Most disc brake kits $315 SHIPPED!
Don't be tricked into thinking the other guy has a lower price. My price includes shipping!
Now on facebook --> www.facebook.com/lugnut4x4
Why buy from Lugnut4x4?
1. I try to have the best price. I don't know of anyone cheaper. My basic kit is $315 shipped. Other companies are similar on price, but charge very high shipping.
2. I try to provide the best quality. I use custom made stainless steel banjo bolts. Why? Because regular ones rust and they can be hard to paint. I use Wagner pads instead of cheap China pads. I include new wheel seals. If you are going to have it apart, why not put new seals in? I also provide all new grade 8 zinc coated hardware.
3. I ship fast! I use priority mail so I can ship anywhere in the USA in 2-3 days. My competitors use ground service and wait a few days before shipping.
4. Options! - Most kits have five different calipers to choose from, rubber or stainless hoses, different pad options, and even slotted rotors for most kits.
5. Nobody can beat my service. As a small business all questions are answered be me, the owner. I specialize in brake kits and have kits for axles that nobody else does. I have all Lugnut4x4 emails forwarded to my phone so I can reply within minutes most of the time. Every kit includes a business card with my person cell phone also.
6. My brackets can be mounted in different locations because they have more than one set of mounting holes. This allows you to rotate them for custom applications.
I am selling a complete bolt on disc brake conversion kit for $315 including shipping to anywhere in the US by priority mail! Yep I really mean complete - here's what you get:
3/8" thick laser cut brackets (bent if needed because spacers can fail)
New grade 8 zinc coated bolts
new 8 lug 12.5" diameter GM rotors
USA rebuilt GM calipers with steel pistons
high quality semi metallic brake pads
new wheel seals for the inner hub
new caliper pins
rubber flex hoses
Stainless steel banjo bolts
copper washers
anti-rattle clips
I have kits for these axles:
73-87 Chevy single rear wheel full floater 14 bolt axle 10.5" ring gear
62-72 Eaton corporate rear end, full floater ( same kit as the 73-87 14 bolt)
73-87 Chevy cab and chassis full floater 14 bolt axle 10.5" ring gear
88-up second generation 14 bolt 10.5 full floater/ need to know:
if drums slide off after removing wheel-need "gen 2" kit/ if wheel is removed and drum is behind the wheel hub and studs then you need the 73-87 14 bolt kit. (there is no reasoning as to what year will have what, we have seen both versions all thru the 90s)
79-up 14 bolt semi-float 8 lug 9.5" rear axle / not positive what year this axle was first produced / this kit sells for $340.00 because new wheel studs come with it. (no 6 lug axles)
72-up Ford dana 60 rear axle/ have found that it will fit 68-71 ford dana 60 rear axles but slight spacer modification is sometimes required using flat washers.
76-93 Dodge dana 60 rear axle
94-up Dodge dana 60 rear axle - Weld on kit only
68-72 Chevy dana 60 rear axle
72-up Jeep pick-up dana 60 rear axle( jeep took over the gm dana 60 rear axle in 1972 when chevy dumped it in favor of the 14 bolt) same kit as the chevy 60
Ford sterling axle - $390 (uses special rotors)
Other axles? Generally I have found that these same rotors will work on most other axles, but you will need to use weld on brackets. Just tell me the diameter of the tube near the end of the axle and I will send you weld on brackets.
Instructions? Yes, I include basic instructions. This is really simple to install for anyone who has a clue about how brakes work. Only word of advise is most of my kits require the rotor on the backside of the hub.
Emergency brakes? Yes, I have eldarodo calipers for $200 more. This gives a manual e-brake that hooks up to your cables.
Parts list? Yes, I include a list of all the replacement parts with every order.
I accept paypal or most credit cards. Orders will ship from TN by priority mail so you get it quick.
To buy one go to my website --> Products | Lugnut 4x4 | Disc Brake Conversion Kits for Dana 60, 70, 80, 14 bolt and Sterling 10.25.
You can also call me if you want. I can take a credit card by phone, but prefer that you use my website since there is less chance of me writing it down wrong. 423-737-0265 -- Shawn
Upgrade to braided stainless hoses for only $25 more.
Need a good way to explain it to your wife? Here's what worked for Jesse
Shawn I just ordered the kit. Had to clear it with the wife last night explained to her I needed this kit to not die from failed brakes.
1 - 20 of 991 Posts
Send paypal to gubni at comcast dot net and include the year and type of axle you need the kit for.
you got paypal bro!
Have a Kit for C&C 14 bolts?
Yes I do. Same price.
What about a '87 GM D70HD?
Yep, but the dana 70 kit uses a weld on bracket and doesn't include seals. It's also a little cheaper at $300 shipped.
Just need the bottom half of you parts list:
new inner hub seals
caliper pins
rubber flex hoses
banjo bolts with copper washers
anti-rattle clips
How much for that shipped to 80104?
new inner hub seals
caliper pins
rubber flex hoses
anti-rattle clips
PM sent.
Thanks for the orders.
I am selling a complete bolt on disc brake conversion kit for $315 including shipping to anywhere in the lower 48 states! Yep I really mean complete - here's what you get:
I have a 1990 Chevy Dually and would like to put rear disc brakes on it. Does your kit have all the parts or what would I have to add? I installed disc rear brakes on my 1979 CJ7 and your kits looks very much the same. Please provide the price and if you have one kit in.
I use PayPal so if this is ok, I will order a set. Do you have an e-brake?
What info do you need from me or pictures? John
Please email if you have any questions. [email protected]
My kit is complete with no other parts needed.
Yes, paypal is ok.
The standard kit does not have ebrake. For $200 extra we will include special ebrake calipers.
My standard kit is not compatible with dually axles. PM me for details about dually kits.
Do you still have these with the ebrake calipers? Do the calipers have the ebrake lever and spring?
Yes, and yes!
sending paypal right now .... thanks from a former Tri-City Resident :flipoff2:
EDIT: you should probably add in that you refuse payments to non-confirmed addresses via paypal. would have saved me from having paypal put a 1 week hold on my monies ...
60 dics brakes
Will your kit work on a 1998 Dodge dana 60 with 3 1/2 axles tubes?
Brian
Sorry about the paypal problem. I got it fixed.
Brian
Yes, it works on 94-up dodge dana 60 rear axle
I just ordered these brackets before I saw your thread.
http://www.pirate4x4.com/forum/showthread.php?t=649888
Could you work me up a price minus the brackets?
Thanks
Thanks
Without brackets saves $40 so $275
My rear hubs have 1/2" studs in them. Is that what will fit the rotors?
My rotors work with 1/2" and 9/16" studs.
1 - 20 of 991 Posts
