1 - 7 of 7 Posts
Anybody have the numbers and/or measurements for a dana 60 carrier or a dana 61. I picked up a Brand New trac lok carrier, 30 spline, and I think it is a 61 carrier but I need to confirm.
Thanks. Where is the bible? I do believe I have either the 61 carrier for 354-410 ratios, with the big offset, or a d60 410 down carrier. Not sure.
I forgot about the other two ratios. What i stated is true for the 3.07 gearset. Can't be so sure about the carrier that came with the other ratios in a 61.
Thanks. I will just measure and compare to the 410 and down carriers I have, then do comparison and see if it has a 60 offset or a 61 off set.
Mine is a 2.435-2.440 depending on where it is measured. A far cry from the 2.36 for the deepest 60 carrier, I guess I stumbled upon one of the infamous trac lok 61 carriers from a 354-410 geared 61. Thanks.
1 - 7 of 7 Posts
