Dana 60 low pinion rear end housing. Center pinion. Ford big bearing housing ends already installed. Using Moser Engineering shafts this housing is narrowed to 59.625" wheel mounting surface to wheel mounting surface. Shafts are not included.
Its the same width as the one in the buggy. Just a low pinion version. With 15" wheels the width worked out fine in my old CJ. But now with the 17" rims I gotta run wheel spacers due to all the backspacing on the 17" rims. If you put the rotors over the end of the axles I think it gives you another 1/2 to 3/4" of width so that would put it around 60.625" which is pretty close to stock TJ width.
Typo on the add. It measures 54.625 hub face to hub face. So with standard stick out, from the hub face to the wms of 2.5",it should be right at 59.625 WMS to WMS.
