1 - 12 of 12 Posts
Ive got a mystery rear dana 60 with no BOM. Im trying to get a disc conversion kit for it and the brackets are different between makes. Does anybody know how to tell them apart?
Rolling Mod
Post pics. Cause no bom, no info at all, and no pic means you dont get shit for help.
Pretty much this. Or a shitload more details. Width, bolt pattern, spline, SF or FF, tube dia etc.
Discussion Starter #5
I thought it might be simple like certian wheelbases indicate different brands or somthing. I'll try to get pics later.
WMS-WMS is 65"
Tubes are 3 1/4
Full float
the words HD60 are cast into the housing behind the bearing cap
originally it had 16 spline axles.
12" drum brakes presently
wheel lug pattern 8 x 6.5
blatant asshole
With 16 spl its going to be early 70s at the newest
1 axle a wheel base does not make.
Perch spread can often be a good indicator of chassis mfg
Along with hub pilot diam.
That info still covers, gm, ford, dodge, jeep j trucks, and ih
Don't worry about what it came from--throw it away and get at minimum, a later model with the larger spindle bearings. (unless you're going to cut it up and just use the center section...in which case it's just a D60)
1 - 12 of 12 Posts
