1 - 2 of 2 Posts
I have a 1999 2500 with a srw 80 (the D70 shafts and bearings, 35 spline shafts) I want to go to the bigger hub bearings of the DRW 80. The 37 spline shaft will fit through the SRW spindle and the bearing retainer nuts are the same part number from dodge but the 37 spline shaft is longer. The length could be in the hub castings or in the length of the tube from centersection to backing plate. The length could also be in the hub casting and spindle length due to the bearing spacing changing.
I was thinking I could put the dually hub on my srw housing or machine my srw hubs to accept the larger bearings but the bearing spacing is still in question and I can't find anyone that will let me take apart the dually:D go figure.
Does anyone know if you can put a dually hub on a SRW 80?
Or if you have a dually could you measure from the centersection to backing plate for me?
Discussion Starter · #2 ·
future reference:
DRW tube casting to backing plate on drivers side: 18.75 inches
SRW tube casting to backing plate on drivers side: 20 inches
1 - 2 of 2 Posts
