1 - 14 of 14 Posts
IH/Rover Moderator
Many of the handicap buses are front wheel drive and use a D80 front axle. The rear is single wheel for a flat floor for wheelchairs.
i have one in my tow rig :D i know they were an option in alot of the newer ram 2500 and 3500 with the cummins
They were standard in the '94-'02 2500 Cummins powered Rams with a manual and all Cummins powered 3500s.
Gus
i might be using one in my trail rig if i can get ahold of one. easier to go to 37 spline shafts than a D70 :D
i will have to shave it as much as possible though...what do you want to know?
Discussion Starter · #11 ·
Thanks guys. I am debating on what housings to run under my bgi block Ramcharger. I was originaly thinking about rockwells but I figured the 80's might be a bit easier to get ahold of and retrofit.
Thanks
Discussion Starter · #14 ·
Which do you think would be the tougher setup in the end? A Dana 60 front, Dana 80 Rear or a set of Rockwells? I think I can source a Dana 80 Rear fairly reasonable from the local scrapper.
Thanks
1 - 14 of 14 Posts
