#1 son purchased a 4.88 rev, D60 gear set...so he thought. The pinion bearing fits match the old pinion taken out of the existing housing. The question is , did Dana use a crush sleeve on D60 pinions? The new pinion has a shorter shoulder section then the the old one. When assembled in the housing it seems to need a spacer (crush sleeve) to allow a tight fit. I have asked local experts, they could not remember Dana using a crush sleeve in the 60. My next question is , given the diameters are the same what does this gear set fit? Ring gear is the correct diameter and has the correct number of bolts.
This is my first post to this forum. Please excuse any violations of posting conventions...I'll learn.
Jerry
Jerry
