1 - 8 of 8 Posts
ok, trying to help a buddy put in a easy locker but I am new to this c-clip thing. How do you get em out?? We are here and greasy ;)
I took out the pin, and the 2 smaller spider gears, along with the bearing caps. I can see the c-clips in the spider gears but they need to be pressed in. There is some weird clip on the side thrust washers but trying to get it out I broke part of it and still can't figure out how to get it out..
thanks!
do you keep all the thrust washers in? The ones that are splined don't fit over the locker and the directions say to use one thrust washer so we used the one slick one the rest are ridged and we left them out. These directions SUCK. I have put in a dozens yota ones - damn jeeps ;)
If I use the spined thrust washers I gotta grind to make em fit, how cheezy is that?
well actually it is ok - but I did have to grind the grooved thrust washers. All's well, I think ;)
I can't believe they use a rubber fill plug and it isn't threaded!
1 - 8 of 8 Posts
