I am in the middle of this Dana 44 swap on my Toy <IMG SRC="smilies/bounce.gif" border="0"> . I am supposed to set the caster at positive 6 degrees, is this corrrect? If I set the caster to 6 positive degrees then my pinion will be pretty much level with the ground <IMG SRC="smilies/rolleyes.gif" border="0">. So now I'm thinking that I'll set the caster at 6 degrees then rotate the pinion up (read: rotate the tubes in the knuckles) to point at my driveshaft.
How many degrees of caster are you guys running with your Dana 44 fronts? I just need to know how much caster is good so that the truck drives and steers as it should.
I just wanetd to bounce this off of you guys to get some advice.
thanks <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0">
