1 - 4 of 4 Posts
I looked at a lot of stocker trying to figure out where to set mine. they were all close to 0 +- 2. So I tryed some 3degree shims and then 6. Looks close to stock. For driveabilaty and 4-5 would have been beter. I hope that helped. I could not find the exact answer eather
Steve
Originally posted by overeasy:
<STRONG>I looked at a lot of stocker trying to figure out where to set mine. they were all close to 0 +- 2. So I tryed some 3degree shims and then 6. Looks close to stock. For driveabilaty and 4-5 would have been beter. I hope that helped. I could not find the exact answer eather
Steve</STRONG>
Thanks overeasy. That helps. Im trying to figure out if I should add more than 6* of caster to this Wagoneer front end that I'm putting under my Toy. If I have the stock caster nummber for Toyota then I can have something to compare to.
How do you actually measure degrees of castor?? I just "eyeballed" mine, since it wont see the road much.
So what do you use to measure?, and where do you measure from?
Thanks,
1 - 4 of 4 Posts
