Some reasons to buy from www.TrickTools.com: We have an excellent reputation with a whole crew of fabricating experts that provide exceptional customer service and technical support on a daily basis. Any application questions, warranty issues, replacement parts or problems of any kind are dealt with by us. We will work with the manufacturer to take care of you. When you order a deluxe bender kit, mention "Pirate" and you will receive your choice of a free pint of paste lube or $20.00 off of our Bend Tech Tube Bending Layout Software.
The JMR Series of hydraulic tube benders are precision machined units that offer large capacities, fast hydraulic systems, and unique portability. This unique hydraulic system is the only bender that has an air return cylinder, for quick and consistent returns, regardless of the age of the cylinder.
Deluxe JMR Model 1005 Air / Hydraulic Kit Features:
Rolling pedestal with 3-leg design that works on uneven surfaces
Pump storage tray
Die storage pegs
Degree wheel
Unique Air Return on the cylinder
Billet Dies available in 120 and 240 degrees
Aluminum bronze bushings at pivot points
Black coated finish
Built for industrial use and yet affordable
Lifetime guarantee against breakage on dies
Lifetime replacement on US-Made Hydraulic pump
Ships UPS!
Specifications
Will bend .250 wall 4130 Tube up to 2" OD
Will bend .120 wall 4130 in 2-1/2" OD
Follower blocks case hardened .050 min
All pins made from heat treated 4140
2-1/2" Round Tube, 2" Square Tube, 2" Sch 40 Pipe Capacity
If you have any questions, need technical assistance or would like to place an order, please reply to this message or give me a call.
Shane Henderson
1-877-826-7268 x106
[email protected]
