1 - 7 of 7 Posts
Can anyone tell me if a detroit from a ttb44 will work in a 78 d44. both ar 30 spline and both have the same gear split but I don't know if they will work
yes :flipoff2:
http://www.eaton.com/EatonCom/Produ...m?ssSourceNodeId=5334&ssSourceSiteId=EatonCom
1983-96 Dana 44 C-Clip 1.31” 30 3.73 & dn 913A334 813A014
3.92 & up 913A333 813A014
To 1982 Dana 44 1.31” 30 3.73 & dn 187SL16D 913A334 813A014
3.92 & up 187SL16C 913A333 813A014
1977-79 Dana 44 8.5” dia. r.g. 1.31” 30 2.72 187SL16D 913A312 813A014
http://www.eaton.com/ecm/idcplg?Idc...aveAs=1&Rendition=Primary&&dDocName=CT_128481
that last link is the coolest one, I just noticed the bottom tabs give an exploded image and part numbers for every piece of the locker
Carrier will interchange. Carrier bearings will not ( taper is different ), so you must use carrier bearings for the housing the differential is being used in.
1 - 7 of 7 Posts
