1 - 5 of 5 Posts
I have an old '75 GMC dually with an 8.1 and Gearstar 4L80E (stage II).
I towed a 10000lbs dozer on my GN about 4 miles up a very steep dirt road and actually ran out of power and had to be pulled via tow strap by another truck to the top. I tried to nurse it as much as I could. I had the gearstar tranny cooler and fans running the entire time. Once I was at the top I went another mile down hill and parked it overnight. Next day unloaded the dozer and drove it a few hundred yards and it has sat ever since. Seemed fine then.
Fluid smells fine and is not low. I think it overheated to the point where it was coming out the top of the tranny breather.
This was at night at about 50 degrees.
Think I damaged the Gearstar 4L80E?
Newb
Trans fluid will discolor with heat (red > brown > black), if it's still bright Kool-Aid red it's probably ok.
4X4 HACK
Clarify "ran out of power"?
Did your engine overheat?
You sure your trans wasn't over full?
I've read that 240*F is the beginnings of overheating a trans.
1 - 5 of 5 Posts
