181 - 200 of 317 Posts
Your only as good as your weakest link and you are ferreting out yours.
Skip
What are your thoughts on the drum disconnect? I have been thinking about buying/building one of those...
Discussion Starter #184
The standard free-spool on the winch is more or less useless because you have to turn all the gears around, i.e. very heavy to free-spool.
I have always powered out my line because it's easier.
With the air free-spool I can free-spole with the line pinched with only to fingers, that is how easy the drum turns.
That saves a lot of time and also saves my co-driver when we are competing.
As a bonus my youngest son (8 years) can easily handle the winch line when we are to an off road meet.
Discussion Starter #189 (Edited)
Can you build a new replacement frame where you live?
Discussion Starter #191
Yes and no
If i do it would be treated lika an amatuerbuild and will get a new title with year 2018 on with tax and everything
But I can repare the frame I have as long as Ii roughly follow the original frame
Shape and design
Any big changes planned for this rebuild, or just taking everything back to where it was before?
Discussion Starter #195
Discussion Starter #196
The plan for the moment is:
* Toyota LJ70 axles with ARB front and rear
* Three link with panhard front
* Coil springs with shocks
* Toyota steering box
* Same Engine and trans as before
* New tube fenders at front looking like the standard fender but with more raise
* Frame connectors for the cage
* New fuel tank so I will pass race inspection (changed regulations)
And of course it should stay low as before
If time allows I will do radius arms with panhard at the rear and 5 speed gearbox
But the time is the deciding factor for the rear.
2018-01-10 21.14.21 by Jonas Schiller, on Flickr
2018-01-10 22.33.52 by Jonas Schiller, on Flickr
I have learned something from someone here...:)
Every bracket have a paper template and a cutting template
I'm curious, why would you want to choose to do a radius arm rear suspension?
Discussion Starter #199
Long time no see...
After King Of The Hammers I just didn't felt for the projekt until beginning of July.
But the projekt is not dead and yesterday it stood on it's wheels by it self:)
It was a really good feeling 11 month after I started disassembly the car.
Good stuff. I'm happy to see you back at it.
