201 - 220 of 317 Posts
Discussion Starter #202
I'm not going to write a lot just show the pics
Discussion Starter #203
Cutting template for the plasma
Sleve through the frame
The other side
Discussion Starter #204
When i bought the axles there where after market hightsteer arms fitted.
If I would have kept them, I'm only got 1" of up travel on the suspension.
so this is the plan.
Discussion Starter #205
I added frame connectors for the cage.
the plane is that they stop the tube from cracking.
I build the suspension to be able to have as much up travel as the frame allows.
All brackets that might need to be replaced in the future have wood templates.
Rear frame connector and radius arm mount are built as one strong unit.
Planed ride height
Rear pinjong angle at ride height
A shave is planned for the axles
Discussion Starter #206
Front axle at maximum possible full bump
Roughly where the motor gone end up.
We where in Amsterdam on our summer holiday.
In a normal convenient store I found this beer:eek:
The rebuild looks great!
What is the reasoning behind the rear radius arm vs something like a 3/4/5-link system?
I always wondered what wheeling/offroad modification was like outside of the US, maybe me and the wife can move to Europe lol.
Sent from my SM-N960U using Tapatalk
Discussion Starter #209
The reason is that I have had an extremely stabil car on sideslopes etc. and I try to keep that, with the radius arm I get like a built in sway bar.
Why a not so flexy rear end vs front end?
My experience is that if you get the front wheels true the obstacle the rear wheels will easier follow.
That is an interesting way to think about it. In my experience the radius arm rear will have some rather severe jacking/lifting issues when under power. This is magnified when the vehicle is climbing and on a higher traction surface.
Discussion Starter #211
Time for some motor mounts
Passenger side
Driver side
Rear motor/trans mount
On this picture you could also se the sleeves for the radius arm mounts.
I would have liked to have the rear mounts on top of the frame but then I coulden't remove the trans with the tub on, so they had to be on the inside of the frame rail.
Discussion Starter #213
Same reinforcement as standard Willys frame
Are now also welded in between the spot welds
Motor mounts
Discussion Starter #214
I ordered a new winch mount from a local shop
Made new plates to weld in the radius arms
I also made a reinforcement between the lover bushing and the upper tube.
The finished arm
The angle of the arm at ride height
Discussion Starter #217
I put on the tube so I could move forward.
I decided to make new fenders, the old high line fenders were limiting my flex and up travel.
Temporary tube fenders
Discussion Starter #219
