Picked up one from Gearman and two from a junkyard, noticed that two have much thicker flanges than the one from Gearman. One of the thick-flanged ones is drilled for an ABS sensor at the top, while the other has the same casting but isn't drilled.
Guessing the thicker ones are from newer rigs? But still take the same bearings and gears?
Thicker flange: .410" vs .554"
Looks the same otherwise, has the exact same bolt pattern.
Check it out, the newer one doesn't have the slots to make punching out the bearing race easier.
[ 09-28-2001: Message edited by: Drew Persson ]
