What is the differences in the housing on D60 rears??
I've found a couple different *styles* and a quick search did not lead me to a good thread on the differences between them.
I have seen the D60's that look just like a bigger D44, single "rib" around the cover area.
I found a couple other at the pull-a-part that had a double rib (8-lug FF out of a late Ford)
I have also seen housing with more slab sides (almost octagon shape).
not all of them have the little "60" stamped into the web, so I'm not 100% sure they all are D60's. It there and easy way (short of pulling a shaft, if still equipped) of telling a D70 from a D60? I have heard that covers are the same, and I have heard the covers are different.
This is going to be cut down and shaved into a semi-float w/1.5" 35-spline shafts... so its not *that* big of a deal, just if one housing is a better choice than the other....
thanks :beer:
thanks :beer:
