1 - 20 of 32 Posts
Super Moderator
'82 Scrambler, '14 Rzr
So what parts are interchangabe between different Dana 60 fronts - like between Fords, chevy's and Dodges?
I am picking up my Dodge Dana 60 front this afternoon (woohoo!) but it seems one of the ears where one of the calipers bolts on has been cut off... I guess I could weld a replacement on there, but am wondering what donors I could get one from to swap out...
Also, what are the differences in shafts from Dodge to Ford to Chevy?
thanks <IMG SRC="smilies/glasses.gif" border="0">
Thats a tough one, there are MANY little differences in the individual parts. For instance BJ D60's have an integral caliper bracket molded into the knuckle... KP its seperate. Ford stubs, hubs and spindles are a 1/2" shorter than the CHevy and dodge stuff. Chevy spindles use 6 bolts, Frod uses 5, BJ uses 4 they all could be interchange-able if you re-drilled them I believe. Ford rotors and calipers are not interchangable with Chevys... ETC....
<IMG SRC="smilies/massey.gif" border="0">
Super Moderator
Thanks Ant <IMG SRC="smilies/smile.gif" border="0">
The reason I ask, if I may be able to get a set of knuckles off a GM 60 front, and was wondering if they could be swapped to the Dodge 60...
Hey David, Im not sure how much I can help but this is what I have figured out so far. I have a 93 front Dodge D60(last year for leaf spring) and my buddy has an 83 Chevy one. The only thing missing on my front was the calipers. I looked at his and talked to a few other people about it and these are my conclusions. The Dodges and Cheveys are virtually the same from the knuckle out (assuming both are kingpin, pass side diff ect..). I went to my local parts store and got the calipers for an 83 chev K30 instead of the Dodge because they didn't have an application for a D700 Dodge. I did notice that on my inner shafts, they neck down at the splines and where the shaft meets the "ears" on the Dodge <IMG SRC="smilies/crybaby2.gif" border="0"> Doubt it is very easy to break anyway. My friends GM inner shafts are 1.5" thick all the way. But the outer 30 spline stubs were identical on both. I also had a chance to look at a RR driver side diff from an early F350. No way any of that stuff would work it was all different. Basically the compatibility between Dodge and GM is a go and the Ford is of no use to us. BTW, I still need to make sure those calipers are going to fit mine and I will let you know soon if you'd like.
i have a 1979 dodge d-60 front from a d-600 and it has the 8 bolt external hubs. The only problem I have found is that no-one makes an external bolt on hub for a 35 spline stubshaft, so consider that if you were thinking of going to 35 spline stubbies,
Super Moderator
Thanks guys - and yes, I would be interested in the caliper fitment and cost as well (since I will be buying them also).
The axle I am getting has one drive flange, and one Selectro lockout hub.. yet another issue I am gonna have to deal with.
Then again, if I go ARB I may just leave it that way <IMG SRC="smilies/tongue.gif" border="0">
Originally posted by Ant:
<STRONG>Yeah chevy and KP dodge knuckles should be the same. Rebuilt calipers for CHevy D60 are only like $50 each loaded.</STRONG>
Yep, thats about right. And then you have to buy the hardware kit, that thing is like $30. Oh yea, and get ready for some grinding if you are running 15" wheels.
Super Moderator
Discussion Starter · #10 ·
Ok, I pisked up the axle, but I am starting to have doubts about it...
It is missing both calipers - not a big problem I guess.
On one side someone too a torch and cut through the caliper mounting plate - so it would need a new one of those (the sandwish in there and bolt on, right?)
As I said - it has one hub, and one drive flange. It looks like they are not the internal style hubs - is that a big problem, or what?
I just got it, so I don;t know any more than that right now...
Any thoughts on this? Problems? Weaknesses? <IMG SRC="smilies/frown.gif" border="0">
Super Moderator
Discussion Starter · #11 ·
BTW - I measured and it is 67" WMF to WMF
I would be willing to bet you my 60 that it has a 4.88 gear and it is welded up inside. Oh yeah just to know that front end came from a pulling truck from Alabama or Mississipii one. Junk the lock out and run drive flanges and an ARB since you are fond of them and I have never seen one of them break in a 60 <IMG SRC="smilies/biggrin.gif" border="0">
Super Moderator
Discussion Starter · #13 ·
Originally posted by Lo Rent Willy:
<STRONG>I would be willing to bet you my 60 that it has a 4.88 gear and it is welded up inside. Oh yeah just to know that front end came from a pulling truck from Alabama or Mississipii one. Junk the lock out and run drive flanges and an ARB since you are fond of them and I have never seen one of them break in a 60 <IMG SRC="smilies/biggrin.gif" border="0"></STRONG>
Seems like everyone knows the story on this axle bu tme <IMG SRC="smilies/tongue.gif" border="0">
I haven't checked yet, but he never said anything about it being welded... Oh well <IMG SRC="smilies/tongue.gif" border="0">
I was thinking of going that route anyway - ARB and drive flanges would not be a problem <IMG SRC="smilies/glasses.gif" border="0">
Originally posted by Convertiyota:
<STRONG>What's the perch width on that thing just out of curiousity?? <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0"></STRONG>
I know your asking DRM, but my front Dodge is 32.5 center of perches. I am cutting the long side down 3.5" to match the Toy width. BTW mine was dually so it was a little wider due to the hubs. I am having the hubs machined to single wheel offset. Just thought id share
<IMG SRC="smilies/beer.gif" border="0">
Super Moderator
Discussion Starter · #16 ·
I will not be narrowing the housing (at least I don;t plan to right now) so I will be outboarding the springs to fit the perches.
Originally posted by DRM:
<STRONG>I will not be narrowing the housing (at least I don;t plan to right now) so I will be outboarding the springs to fit the perches.</STRONG>
I thought about that, but my rear D60 is only 65" WMS-WMS so It will kinda even out if I narrow the front. Plus I think im going with the 44044's up front so I am going to make a new front mount to get an inch of lift there and move the axle forward some, but I need to check on the 44044 stats again
<IMG SRC="smilies/rolleyes.gif" border="0">
Super Moderator
Discussion Starter · #18 ·
My rear 60 is only about 65"-66" as well, which is perfect for a 67" wide front axle...
First off, those look like D44 rotors in the pic?? Secondly the caliper bracket does bolt on so its cake to change but expensive. You can swap the hubs and lockouts to the internal style which are a bit stronger. Throw on some of Ant's hi-steer arms and your ready to rock!!
Save yourself ALOT of grief and don't run selectros! Go strait to hub flanges. I had "Donovan" who is on this board, make me a set of four flanges. The selectros break very easy, at least for me. <IMG SRC="smilies/smile.gif" border="0"> Also Dynabigbucks is supposed to have flanges now. <IMG SRC="smilies/usa.gif" border="0">
1 - 20 of 32 Posts
