1 - 14 of 14 Posts
say i was to run 38's in the rar of my truck and like 35's in the front, how would one figure out the gearing for each axel so i wouldnt chew up u-joints?
jarvisjeep said:
Mabye insted of using tire height, use the actual tire rolling length. Like if it takes 132 inchs for one tire to roll one rev, then the other one 80 inchs. Use those to find you ratio. It probably wont matter that much, but just a thought.
It could matter quite a bit actually. You could also measure center of hub to the ground.
thanks for the replies, im not actually doing this (yet) but it has crossed my mind for a neat idea of have, but when i do it ill be mesuring the tires, not gunna go by what the sidewall says
Snowbird13 said:
Don't know if you have thought of this, but you will need 2 spares with you.
yeah, unless i run open diffs, then i could get away with a diff size tire to get off the trail, if anything this would be a drag truck so its not going to be in a remote location without access to tools/spare parts easily, its a dream right now but as soon as summer hits ill be lookign for a donor truck to start with. anyone wanna toss any info about building one be my quest, all info is great
By drag truck, I assume you mean mud drags or sand drags. You're talking about a pretty common mod, although most of the guys who do this will spin the front tires slightly faster than the rears (say 3.54 front & 3.73 rear if all 4 are the same size & alter it a bit more if staggered tire size).
I actually posted this video elsewhere just a few minutes ago:
www.gumbo4x4.com/LINN013.mpg
That's obviously not a budget minded truck, but same stuff applies.
TEX
Discussion Starter · #12 ·
TEX said:
Whoops, just recognized your sign-in name - you posted this over on the Stompers sight too, right?
nope, this is the only forum i use for trucks, probly someone else
1 - 14 of 14 Posts
