1 - 6 of 6 Posts
whats the best way?!?!? there is no room the get a hammer in there for a clean shot. the tube isnt straight so you cant just wail on it. i did notice that the new tube has a few bumps before the flare, and the old one didnt. i got the stock part for the engine, so what gives? any thoughts??
Find a pice of 3/8 pipe or whatever will fit, Grind and notch so it will fit aroubd most of the flange on the tube and start Whacking!
If you can, But I would not worry about it.
I've take small deep well sockets and Cut them to fit.
Just make sure your on the flange as much as possable.
If that doesn't work, try a flare nut wrench or vise grips w/the curved jaws. Put it against the flare & wack the wrench. Worked for me :)
1 - 6 of 6 Posts
