I have completed a rear disc swap on my 85 4runner using sky's brackets, 82 monte carlo front calipers,83 fj40 m/c(auto zone) new(this is what all pro sells) and remaned. Front brakes are factory. Have bled the brakes numerous times. No bubbles. Took the remaned m/c off and put on the new m/c. Then removed the pressure cup on the rear brake line on the m/c. Still have soft brakes.
The lift is a 4.5 in superlift with 2in shackles and it has the bracket to raise the connection from the porportioning valve. I do not have a residual valve.
Should i ditch the fj40 m/c and go with the 89 v6 m/c?
Does the porportion valve need to be raised even more?
Any other suggestions?
