1 - 3 of 3 Posts
i know this has been asked a million times and i've searched up all my other info, but could not find this..........if i use chevy spindals on my 75 ford knuckles and also use the chevy stub, what hubs work? ford or chevy? also, does 10 bolt front spindals have the same 6 bolt pattern as chevy d44? thanks
spindle and hub must be from same source (unless cross sources are dimensionally identical - then the original app is mute, as the parts are identical). Stub shaft you will then be able to use will depend.
In your case - use Chev hub
can't answer last part
Grin ;)
OK, ok, ok......so the truth is....I have the info somewhere but can't really be bothered to look it up right now.
Didn't want to seem like a lazy snob tho...so I fibbed!
I really don't "know" that much.....I'm just really really good at research and the collection and organization of data, but I must admit....I'm best at that at what interests me, and I left D44s behind a while ago when I went to 1 tons.
'course what I really want to do is leave the 1 ton behind and go to 2.5 tons :)
1 - 3 of 3 Posts
