1 - 5 of 5 Posts
have any of you guys used a DIVORCED Toyota Transfer Case Adapter to run dual cases? The adapter i was looking at is from OTT industries so it's good quality, but i'm not 100% sure how it works......there's no range box correct? So you will be left with an extra front driveshaft output? Can someone set me straight?
I dont know about anything new but the adapter OTT makes that I know of is normally used behind a 2wd tranny or something that wont mate directly to a toy case. Not normally used to make dual cases as it would be very lon and you would have an output in the way. Also, my buddy went through several different mounts and setups with his divorced case. He just recently got rid of it and went to a regular toy tranny and case setup. No more vibration and the slop is reduced.
ok i kinda figured it wouldn't work the best BUT i have a g58 trans with the chain t-case so i have to use this until i swap my trans.
1 - 5 of 5 Posts
