1 - 20 of 43 Posts
2 years ago I was bored of my Cherokee buggy (will post some pics of her later) Friend of mine has a line on newer 14b and Snowfighter 60 for $1500. I let the guy sit on them for a while. I ended up scoring the axles already cleaned up with some links for $1000.
Few weeks later stumble upon a set of 42” Iroks and Stazworks wheels for $1200.
Has them laying around for a few weeks, tossed around the idea of just gluing them under my Cherokee but had the itch to do a full new build.
Scoured CL for a cheap CJ7 or YJ, ended up finding a 74 DJ5 for $400 with title.
Brought it home and started eyeing everything up.
Tossed the factory frame and running gear. Built a copyish frame of the factory out of 2x3 3/16.
The plan was to keep it low as possible. The grille was too tall and would have hit the ram mount at what I wanted to be full bump.
I ended up sectioning 5” out of the grille and it got me to where I wanted to be.
Discussion Starter #2 (Edited)
After getting wheelbase and ride height about where I wanted it I started on setting up the links.
The old lady for comparison on the sweet poser flex and a broken engine hoist cycling everything. Everything worked out and I was happy with it.
Sourced up a newer non vortec SBC 350 for $400. After about 10 times of the tub on and off the motor was set where it was happy.
I officially had a roller.
Later sourced up a TH400 and D300 on the cheap. Weather started getting cold and pulled her into the garage at my dads place. Started working on getting the ORIs mounted.
After hitting a building block and a few nights of staring at it. I decided I wanted to chop the windshield. My old man being the old school body guy he is suggested I don’t chop the frame itself and lose visibility. Instead section the frame where it meets the cowl/top of the dash. I was able to keep it he full size window frame but drop it down 4”.
Happy with that it was time to start the cage.
Discussion Starter #3
Got most of the cage work and heavy fab finished and up around spring time and the old lady found a place that had a garage. We loaded up the Jeep and within the last half mile of the transport I had a strap break.
That was exciting to say the least, got her back on the trailer and finally home.
Got to the sheet metal work, floors dash and center console.
Finished sheet metal and pulled the trigger on a set of rear ORIs, waited 8 months for them to show up an piddled around with some little shit on the Jeep. It was pretty much on the back burner.
ORIs finally showed up and got to mocking them.
First mounting attempt was a no go. I thought I had way less backspace on my Stazworks. Tires got into them pretty quick.
I ended up moving the lower mount from the axle tube back and down onto the truss, that gave me enough room to drop the tops closer to the tub and gave me my proper clearance.
Discussion Starter #4
Pushed her outside to have a look, this was the first time it was supporting its own weight on all four corners.
Discussion Starter #7
Wrapped up the center console shifters and cutter brake. Still need to add gauges and switch panels.
Once the interior was done I fiddled with the bay. Mounting MC and pedals, propane regulator battery box and the like.
The inner fenders were a nightmare. I scrapped quite a bit of oil board before my old lady decided to step in and help out. Got the template figured out and threw the ally sheet in the brake.
Sourced a H.D. rear output for the D300 only to find out its for a short tail after getting it back together.
Discussion Starter #8
That brings it to now. Waiting for parts for the front axle. I ordered up some 35spl outers from a made in China eBay gear supply store. They look decent in the machine and finish department, however I doubt they are as strong as advertised. We will see, they were cheap and RCVs are in the plan later on down the road.
Started to work on my flat belly, or almost flat, trans pan hangs about 1/2” lower than the frame rail. Hindsight I should have made the drop in the center of the frame a bit longer. I’ll post updates as I get it going and as more parts start to show up.
Discussion Starter #10 (Edited)
Fiddled around today. Got some spicer joints partial KP rebuilds, (lower bearing and race upper and lower seals) and stub/spindle seals from ECGS.
The made in China 35spl stubs took the joints 100% better than I expected them to.
Discussion Starter #11
Spent the last few days balls deep in old grease doing new king pins, bearings and seals. Pain in the ass. Minus brake lines the front axle is finally done.
Discussion Starter #12
Knocked out brake lines today. One fucking line nut short of finishing the whole system. :rolleyes:
Discussion Starter #13
Just realized this is in non hardcore, my dumbass, could one of the mods move it to the hardcore section please? Yeah that’d be grrrreat.
Discussion Starter #14
Ordered a JB conversions HD don’t output for the 300 so I can get it back together.
Looking at the Novak super short rear output, anyone have a coupon code or anything? Not too hip to the $600 price tag, unfortunately I need it however.
Discussion Starter #15
Got my D300 output and a few other misc parts.
Decided to pull the motor and clean up and prep the bay.
Gonna drop the block off at the machine shop and my D300 bearing retainer at the other machine shop this week.
Discussion Starter #20
Block getting dropped off at the machine shop tomorrow for a bore, deck and cam bearing install.
Can’t wait to see the look on the guys face when I pull an SBC off the front seat of my Ranger. :laughing:
1 - 20 of 43 Posts
