rebuilding a 4.0 and the lower main bearings....you can rotate them along the crank just a bit, like 1/8"
is this right?
is this right?
93yjsahara said:i haven't even put the caps on yet, but you can slide the
........fixed it for you, I think.
No main bearing I've ever installed will move around within the cap or saddle. Sounds to me like you have the wrong bearings. Each half should be a snug fit into it's cap or saddle, almost a "snap-in" fit.
bigfodee said:i checked the crank with micrometers
thats the thing, if anything was bored the STD bearings would be too big, not too small
