1 - 6 of 6 Posts
I found these here.
http://www.portjeff.net/df5152/2003_diagnostic_codes.htm
To get the code , turn the key on and off 3 times. On the last time leave the key in the on position and the code will appear were the mileage is.
2003 codes:
P0016 Crankshaft/Camshaft Timing Misalignment/Out-of-Sync
P0071 Ambient Temperature Sensor Performance / Rationality
P0072 Ambient Temperature Sensor Low
P0073 Ambient Temperature Sensor High
P0088 Fuel Rail Pressure Too High
P0106 Manifold Absolute Pressure Sensor Performance / Rationality
P0107 Manifold Absolute Pressure Sensor Low
P0108 Manifold Absolute Pressure Sensor High
P0111 Intake Air / Charge Temperature Sensor Performance / Rationality
P0112 Intake Air / Charge Temperature Sensor Low
P0113 Intake Air / Charge Temperature Sensor High
P0116 Engine Coolant Temperature Sensor Performance / Rationality
P0117 Engine Coolant Temperature Sensor Low
P0118 Engine Coolant Temperature Sensor High
P0128 Cooling System Error / Thermostat Rationality
P0148 Fuel Delivery Error
P0169 Water-in-Fuel Detected For Too Long
P0192 Fuel Rail Pressure Sensor Low
P0193 Fuel Rail Pressure Sensor High
P0201 Fuel Injector 1 Circuit
P0202 Fuel Injector 2 Circuit
P0203 Fuel Injector 3 Circuit
P0204 Fuel Injector 4 Circuit
P0205 Fuel Injector 5 Circuit
P0206 Fuel Injector 6 Circuit
P0217 Coolant Temperature Too High
P0219 Engine Overspeed
P0234 Turbocharger Overboost Condition
P0236 Turbocharger Boost Pressure Sensor Performance / Rationality
P0237 Turbocharger Boost Pressure Sensor Low
P0238 Turbocharger Boost Pressure Sensor High
P0251 Injection Pump Fuel Valve Feedback
P0300 Multiple Cylinder Misfire
P0301 Cylinder 1 Misfire
P0302 Cylinder 2 Misfire
P0303 Cylinder 3 Misfire
P0304 Cylinder 4 Misfire
P0305 Cylinder 5 Misfire
P0306 Cylinder 6 Misfire
P0335 Crankshaft Position Sensor Circuit
P0336 Crankshaft Position Sensor Performance
P0337 Crankshaft Position Sensor Circuit Low
P0338 Crankshaft Position Sensor Circuit High
P0340 Camshaft Position Sensor Circuit
P0341 Camshaft Position Sensor Performance / Rationality
P0381 Wait-to-Start Lamp Inoperative
P0461 Fuel Level Sensor 1 Performance / Rationality
P0462 Fuel Level Sensor 1 Low
P0463 Fuel Level Sensor 1 High
P0477 Exhaust Pressure Control Relay Low
P0478 Exhaust Pressure Control Relay High
P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)
P0483 Cooling Fan Speed
P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1
P0514 Battery Temperature Sensor Performance / Rationality
P0516 Battery Temperature Sensor Low
P0517 Battery Temperature Sensor High
P0521 Oil Pressure Sensor Performance / Rationality
P0524 Oil Pressure Too Low
P0532 A/C Pressure Sensor Low
P0533 A/C Pressure Sensor High
P0541 Intake Air Heater Relay 1 Low
P0542 Intake Air Heater Relay 1 High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0572 Brake Switch 1 Low
P0573 Brake Switch 1 High
P0580 Speed Control Multiplexed Switch 1 Low
P0581 Speed Control Multiplexed Switch 1 High
P0602 Control Module Programming Error/NotProgrammed
P0604 Internal Control Module RAM Integrity Failure
P0606 Internal ECM Processor
P0607 ECU Internal Performance
P0622 Generator Field Control Circuit
P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low
P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High
P0630 VIN Not Programmed in PCM
P0633 SKIM Key Not Programmed in PCM
P0642 Sensor Reference Voltage 1 Circuit Low
P0643 Sensor Reference Voltage 1 Circuit High
P0646 A/C Clutch Relay Circuit Low
P0647 A/C Clutch Relay Circuit High
P0652 Sensor Reference Voltage 2 Circuit Low
P0653 Sensor Reference Voltage 2 Circuit High
P0698 Sensor Reference Voltage 3 Circuit Low
P0699 Sensor Reference Voltage 3 Circuit High
P0700 Transmission Control System (MIL Request)
P0837 Four Wheel Drive (4WD) Switch Performance / Rationality
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P1652 J1850 Communication Bus
P2121 Pedal Position Sensor 1 Performance / Rationality
P2122 Pedal Position Sensor 1 Low
P2123 Pedal Position Sensor 1 High
P2127 Pedal Validation Switch 2 Low
P2128 Pedal Validation Switch 2 High
P2146 Fuel Injector Group 1 Supply Voltage Circuit
P2149 Fuel Injector Group 2 Supply Voltage Circuit
P2266 Water in Fuel Sensor Circuit Low
P2269 Water in Fuel Condition
P2502 Charging System Output Voltage
P2503 Charging System Output Low
P2504 Charging System Output High
P2509 ECM/PCM Power Input Signal Intermittent
P2607 Intake Air Heater Relay 2 Low
P2608 Intake Air Heater Relay 2 High
P2609 Intake Air Heater System Performance
96 - 01 codes gas and CTD:
P0112 Intake Air Temperature Sensor Voltage Low
P0113 Intake Air Temperature Sensor Voltage High
P0117 ECT Sensor Voltage Too Low
P0118 ECT Sensor Voltage Too High
P0121 Accelerator Pedal Position Sensor Signal Volts Do Not Agree w/Idle Validation Signal
P0122 Accelerator Pedal Position Sensor Signal Voltage Too Low
P0123 Accelerator Pedal Position Sensor Signal Voltage Too High
P0125 Engine Is Cold Too Long
P0168 Decreased Engine Performance Due To High Injection Pump Fuel Temperature
P0177 Water In Fuel Sensor Voltage Too Low
P0181 Fuel Injection Pump Failure
P0215 Fuel Injection Pump Control Circuit
P0216 Fuel Injection Pump Timing Failure
P0217 Decreased Engine Performance Due To Engine Overheating Condition
P0219 Camshaft Position Sensor Overspeed Signal
P0222 Idle Validation Signals Both Low
P0223 Idle Validation Signals Both High (Above 5 Volts)
P0230 Transfer pump Circuit Out Of Range
P0232 Fuel Shut-Off Voltage Too High
P0234 Turbo Boost Limit Exceeded
P0236 MAP Sensor Too High Too Long
P0237 MAP Sensor Voltage Too Low
P0238 MAP Sensor Voltage Too High
P0251 Fuel Injection Pump Mechanical Failure Fuel Valve Feedback Circuit
P0253 Fuel Injection Pump Fuel Valve Open Circuit
P0254 Fuel Injection Pump Fuel Valve Current Too High
P0301 Misfire Detected, Cylinder No. 1
P0302 Misfire Detected, Cylinder No. 2
P0303 Misfire Detected, Cylinder No. 3
P0304 Misfire Detected, Cylinder No. 4
P0305 Misfire Detected, Cylinder No. 5
P0306 Misfire Detected, Cylinder No. 9
P0310 Misfire Detected, Cylinder No. 6
P0320 No RPM Signal To PCM
P0336 Crankshaft Position Sensor Signal
P0341 Camshaft Position Sensor Signal
P0370 Fuel Injection Pump Speed/Position Sensor Signal Lost
P0380 Intake Air Heater Relay No. 1 Control Circuit
P0381 Wait To Start Lamp Inoperative
P0382 Intake Air Heater Relay No. 2 Control Circuit
P0387 Crankshaft Position Sensor Supply Voltage Too Low
P0388 Crankshaft Position Sensor Supply Voltage Too High
P0400 Exhaust Gas Recirculation (EGR) Flow Malfunction
P0460 Fuel Level Unit No Change Over Miles
P0462 Fuel Level Sending unit Volts Too Low
P0463 Fuel Level Sending unit Volts Too High
P0500 No Vehicle Speed Sensor Signal
P0522 Oil Pressure Voltage Too Low
P0523 Oil Pressure Voltage Too High
P0545 A/C Clutch Relay Circuit
P0562 Charging System Voltage Too Low
P0563 Charging System Voltage Too Low
P0601 PCM Internal Controller Failure
P0622 Alternator Field Improper Switching
P0712 Trans Temp Sensor Voltage Too Low
P0713 Trans Temp Sensor Voltage Too High
P0720 Low Output Speed Sensor RPM Above 15 M.P.H.
P0743 TCC Solenoid/Trans Relay Circuits
P0748 Governor Pressure Sol/Control Trans Relay Circuits
P0751 OD Switch Pressed (Lo) For More Than 5 Minutes
P0753 Trans 3–4 Shift Sol/Trans Relay Circuits
P1283 Idle Select Signal Invalid
P1284 Fuel Injection Pump Battery Voltage Out Of Range
P1285 Fuel Injection Pump Controller Always On
P1286 Accelerator Pedal Position Sensor Supply Voltage Too High
P1287 Fuel Injection Pump Controller Supply Voltage Low
P1291 No Temperature Rise Seen From Intake Air Heaters
P1295 Accelerator Pedal Position Sensor Supply Voltage Too Low
P1388 Auto Shutdown (ASD) Relay Control Circuit
P1389 No Auto Shutdown (ASD) Relay Output Voltage At PCM
P1475 Aux. 5 Volt Output Too High
P1488 Aux. 5 Volt Output Too Low
P1492 Battery Temperature Sensor Voltage Too High
P1493 Battery Temperature Sensor Voltage Too Low
P1594 Charging System Voltage Too High
P1595 Speed Control Solenoid Circuits
P1597 Speed Control Switch Always Low
P1682 Charging System Voltage Too Low
P1683 Speed Control Power Relay Or Speed Control 12 Volt Driver Circuit
P1688 Internal Fuel Injection Pump Controller Failure
P1689 No Communication Between ECM & Injection Pump Module
P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor
P1691 Fuel Injection Pump Controller Calibration Failure
P1693 DTC Detected In ECM Or PCM
P1694 No CCD Messages Received From ECM
P1698 No CCD Messages Received From PCM
P1740 TCC Or OD Solenoid Performance
P1756 Governor Pressure Not Equal To Target At 15–20 PSI
P1757 Governor Pressure Above 3 PSI When Request Is 0 PSI
P1762 Governor Pressure Sensor Offset Improper Voltage
P1763 Governor Pressure Sensor Voltage Too High
P1764 Governor Pressure Sensor Voltage Too Low
P1765 Trans 12 Volt Supply Relay Control Circuit
P1899 PNP Switch Failure
I am getting this code, truck won't start. I am getting fuel to the vp44, but do not know what the pressure is. Does this mean my LP is shot?
Emievil....sorry man I am still learning this shit myself.
Replaced my lift pump. Got the 1693 code now. Fawk this thing is pissing me off. Ordering a vp44 today. Well if I can afford to order one I will.
On the P1689, the first thing to check is fuel pressure.
Then disconnect the battery's, clean the connections to the apps, ip, ecm and pcm. Also any inline connections between any of these. Look for any ground connections that need to be cleaned also.
After reconnecting the battery's unplug the ip, check the voltage to the top 2 pins should be the same as the battery the key has to be turned on. This is quick test to make sure the ecm is not bad.
Next reset the appps.
If all this don't work, the ip is going out.
Like I said I went though this about 2 months ago. I had just replace the ip, the new one was bad.
I had a Dodge mechanic give me the list of thing to do. The also said that most of the time with the P1689 code the ip was bad. The electronic in the pump are bad.
1 - 6 of 6 Posts
