You'll have to choose whether you will sleeve the outside or inside, then find a piece that measures, outside or inside, to a close diameter. You will most likely want to machine the surfaces to create a nice snug fit that will likely need to be pressed together. Plan to use something like 3/8" thick DOM tubing for this. You'll also want to drill holes in order to do plug welds, if you truly want to strengthen the factory setup.
