1 - 7 of 7 Posts
Hi guys, I'm trying to get an engine harness for my 90 pickup. I've found a few, but i'm not sure if they work correctly. First of all, my truck is a 22re 4wd 5speed truck. I've found 2 different people selling harnesses, both are a bit different from mine. One has the exact same ECU numbers but came off a 2wd. The other has different numbers, but came from the same year and is listed to come from a 4spd manual. I just need to know if these would plug in ok and work correctly, and if so, which would be better? Thanks in advance!
22re w/a 4 spd manual? :confused:
My 86 had a five speed, and most of the 2wd's that I've seen came with 5 spd's. Are you sure it was a 4spd?
do it. the harness should work, if they are 5 speed and one is auto, you will run into probs but they need to be about the same year, there are a few different versions of the toyota efi out there.
Both are manual transmission. one has same ecu numbers but is 2wd. Other is 4spd Manual transmission and 4x4. Both exact same year. I just wanna know which would be a better bet.
1 - 7 of 7 Posts
