1 - 9 of 9 Posts
Man Child
Does a harmonic balancer go bad? *Update
'90 V6.
I noticed today a strange rattleing noise. As near as I can tell it is coming from the harmoic balancer. The motor only has about 20K miles on it. I don't know if the original balancer was used after the build but I would guess it was, if so it has about 200K miles on it.
Is it possible that the balancer is bad or do I have bigger problems?
Rich-
Probably your best bet is make a phone call to a local auto shop and ask them about it. I personally have not heard of such a thing but you might want to ask someone who has dealt with a lot of things coming in and out of the shop. What kind of noise is it making exactly?
Priest said:
'90 V6.
Could it be the water pump?
Man Child
The water pump and false water pump idler thing are both good.
I took it into a friends shop this morning and he almost immediatly said that it sounded like the idler/tensioner for the timing belt. He said that this is a farily common failure for those motors. He was going to tear into it in the next day or two and let me know for sure.
Man Child
Discussion Starter · #9 ·
Just got a call from the shop. It appears that somehow the harmonic balancer came loose and was just kind of flopping around. The crank is fine but the balancer did get galled up so a new one is on it's way.
Thanks for the help guys.
1 - 9 of 9 Posts
