*Knock on wood* Have yet to have a problem with either my Jackson NexGen or Miller Elite, though I hate the Elite, and it was free. :grinpimp: Jackson battery life sucks too, next hood will be Speedglas prolly.
*Knock on wood* Have yet to have a problem with either my Jackson NexGen or Miller Elite, though I hate the Elite, and it was free. :grinpimp: Jackson battery life sucks too, next hood will be Speedglas prolly.:lmao: ....auto lens problems :flipoff2:
I had 2 auto hoods. One miller. One Jackson. Only reason either started fucking up was batteries dying. Batteries died one day in the Jackson after the headgear broke on my miller and pulled out my Tillman slider and have been using it for years now. Shade 11 FTW!
HF AC radiates a large amount of RF noise. Don't believe that? Do some research. Unless electronics are very well shielded, they will be affected. My machine uses a spark gap for part of the HF generation, spark gap is far noisier than many modern machines.Not calling you or anyone a liar but that just seems completely illogical that Hi freq. would cause any issues with the lens turning on or off. Considering what a major role that hi freq. plays in a lot of welding operations, if it was causing a problem with a safety device, I would suspect osha would be on top of it and have some specified safety procedure called out for welding with hi frequency. I also don't entirely know what I'm talking about so I'll be staying tuned to this thread in hopes of someone posting some more technical information without my having to put out the effort to goresearch it myself. :laughing:
THIS! :laughing: no matter what, I still do it. Just a habitYou know to this time unless my hood is pretty much wedged that it can`t move I still nod my head
To clarify my earlier post. What I meant with the comment about osha was not about the HF being harmful but rather that it would create an unsafe work environment by "deactivating" an piece of PPE that is an automatic safety device.HF AC radiates a large amount of RF noise. Don't believe that? Do some research. Unless electronics are very well shielded, they will be affected. My machine uses a spark gap for part of the HF generation, spark gap is far noisier than many modern machines.
There is no safety hazard. It has been beat to death before, but any osha approved hood will provide the same radiation protection whether the lens darkens or not.
As far as I know, the only welding process that uses a High Frequency ac component is tig welding. It is commonly used to start the arc, and help keep the arc stable while doing AC tig welding. DC tig using scratch start or lift arc has no HF ac. DC mig/stick uses no HF AC nor does AC stick.
I expect that the reason not everyone has experienced this is because conditions and equipment very greatly. Also, things like having your welding table bonded to earth as well as bonding building steel to earth can significantly reduce radiated RF. I switched to using a fixed shade gold lens a long time ago specifically because of this problem. Probably moving to a modern machine would go a long ways, but for my my old Dialarc meets my needs pretty much exactly.
Later,
Jason
This has been my experience as well, i have had a depress of the pedal activate my Jackson once or twice, but no harm done.To clarify my earlier post. What I meant with the comment about osha was not about the HF being harmful but rather that it would create an unsafe work environment by "deactivating" an piece of PPE that is an automatic safety device.
I do understand that RF interference causes issues with other electronic devices. I've been tig welding on nearly a daily basis for the last eight to ten years and never once have I experienced an issue with HF causing my auto dark hoods to flicker. I have used at least 5 different brands or models in that time period including a Harbor freight $50 hood all the way up to my Speedglas I use now. As I said, to me it is completely illogical that a welding hood that is intended for use with all welding procedures would not be shielded against that interference or a warning posted on the side of it that it may malfunction during use on HF welding procedures.
I loved my speedglas, untill i used a miller.SpeedGlas for the win.
My Speedglas actually has a TIG setting. Turn the knob to TIG, TA DA! works fine.
Maybe time to stop using a helmet that says "PlaySKool" on the side. :flipoff2:
I will agree the SpeedGlas head gear sucks. But I have 2 now, including one that I got as a gift for my 17th birthday. (I'm 33 now)I loved my speedglas, untill i used a miller.
My speedglas 9002 helmet would always switch on and off if i had to tig far away(arms outreached) or around corners and even real close up. (sensors are on the sides)
I bought a miller, have not been flashed once since. and the head strap is sooooo much more comfortable. and i wear my helmets every day so that is a big point for me. i also noticed a big difference now that ive been using the miller in low amp stuff.
I have now put my speedglas into the sacrificial Mig and stick helmet pile. the only selling point on speedglas now for me is the fact they are smaller and fit inside things easier for hard to get places.
My issue with the 2 vs 3 or 4 sensors is that your eyes are not that far apart,even if you can still see the puddle doesn't mean those can. if you have ever welded deep inside something where your hands have to be outside and close to your helmet it really sucks when your hands block the sensors half way through your bead making you have to reposition your head and re-start.I will agree the SpeedGlas head gear sucks. But I have 2 now, including one that I got as a gift for my 17th birthday. (I'm 33 now)
I think the newer one's sensor works alittle better, but I wouldn't say it's a deal breaker. My SpeedGlas has out lasted everyone's brand X helmet.
I get the selling point of "more sensors", but SpeedGlas's explanation is the 2 sensors are in line with your eyes, where you're looking.
Again, to each their own. I weld everyday. I've heard it all when it comes to hoods. I say buy what you like. And when you get sick of your OCC hood with custom flames and you get laughed off a job, go buy a SpeedGlas.
On the other hand, my dad hated his SpeedGlas. He swears that you can get flashed through one and still welds with a Huntsmen. I assure you that's a myth. The auto "shade" you experience is for comfort and the ability to see your work/puddle.
Now, I also have an old Huntsmen for TIG'ing in weird spots where the hood can't "see" and won't trigger. I use it about twice a year.
Supposedly the newest SpeedGlas helmets have really good head gear. I've yet to try one, and they have a few other new cool features I'd like to try one out and pick one up.
