1 - 11 of 11 Posts
Well as scared as I am to post in the HC section I think this is the best place for this. I built the backhalf and cage in my TJ about a year ago and have been running it with the factory half doors since. I have been thinking about selling the doors while they are still in decent shape and installing some door bars. Unfortunately the way we build the cage I am having difficulty figuring out how to add them.
The front down bar is pretty far under the dash making it difficult if not impossible to get a weld all the way around a tube connecting to it., the B-pillar is stock.
This is the best pic I have right now but shows how it is. Like I said the build is done and all welded up so I cannot remove it without cutting it all apart. Any ideas or pics would be appreciated.
Discussion Starter · #8 · (Edited)
Did you want a door or a bar to climb over? You could angle the hinges and lock so that the door part is actually in the door opening
Yeah I don't get it but I just want a single bar that attaches to the B-pillar above the body and runs at an angle down almost to the floor under the dash. I just can't figure out how to weld the bar to the bar under the dash because it's so close to the side of the jeep.
Yes - I have my spare mounted horizontally in the bed of my TJ with 4 of them mounted on the B and C pillers ( 35" tire). That way I can remove it and the mount to haul stuff Those things clamp tight
Cool thanks for the help.
How much can you weld of the bar? 25.5 SFI standards says you must put gussets around the tube that you can't weld all the way around for race cars.
1 - 11 of 11 Posts
