1 - 5 of 5 Posts
i need a double steering arm for the spring over..the one i had doesnt clear the springs too good...anyone want to weld mine up, i have two arms, i just need someone who is confident in welding cast
i feel confident in welding in general,but dont know about the cast metal welding rules adn stuff..i need to preheat then weld it?? i welded cast once but didnt realize it and it welded goood....
OR..
does someone want to do the welding for me? i'll pay you or whatever ($$ or <IMG SRC="smilies/beer.gif" border="0"> )
Peter,
I believe the arms are cast steel so welding is not much of a problem. when I built mine a freind of mine who is a professional welder & machinist gave me some hints. he said to weld the base w/ alot of penetration & BIG welds. he then said to lightly weld the 1/2" plate strut to the arms, full length. I put about a 3/16" bead on them w/ w/ about 1/8"-3/16" penetration. I did this & my arm is extremely strong & I have had no problems w/ it cracking & bending what so ever. I wheel that heavy truck pretty hard.I built mine similar to the www.sierrarockcrawlers.com steeering arm. my arms are fj60 arms so there a little stronger than mini truck arms but much stronger than pre-80 fj40 arms. If youve got any questions just let me know.
HTH
one other thing I forgot to mention is that cooling the arm in sand is a good idea. Do Not quench it w/ water. that was one other thing my buddy recomended to me to keep the arm from getting too brittle.
[ 10-18-2001: Message edited by: sixty ]
Thet're cast arms so you must weld DC- and you should preheat the metal. It's not something you can risk having break so if I were you I'd go to a welding shop and have it TIG welded. Let us know how it turns out. <IMG SRC="smilies/smile.gif" border="0">
Peter, you can send me the arms along with some height clearance info and I'll build you a double steering arm. I'm not sure if I ever really paid you back for all that junk you gave me.
I've done a couple for some of the guys in the club and I also did mine. I use a very fat 3/4" plate steel gusset for support, do the right preheat and lay a very confident bead.
I've punished it severely this summer and it loves it! <IMG SRC="smilies/biggrin.gif" border="0">
Give me a call or send me an e-mail.
[ 10-18-2001: Message edited by: Reddog ]
thanks guys for the response and thanks reddog for the offer, but i made it tonight...it turned out gooooooood..i always say ill post pics but dont have a digi cam or scanner..so you'll have to see it when we meet up for a swap meet or for wheeling.
1 - 5 of 5 Posts
