1 - 9 of 9 Posts
I just got my drill doctor and I was curious about the angle that I should be putting on my bits. should I stick with the standard 118 degree, or should I adjust up or down? I am drilling mainly through thicker steel(3/16 through 3/8)
It dosen't have so much to do with the thickness, but the hardness of the steel. If it's pretty hard, you might want to step up to a 135 degree point. But if it's just mild steel, it will probably just slow you down a bit. Either way is fine, can't hurt.
If you can do split points on your Drill Dr. I'd definently consider doing that to most of the bits.
Which model of the drill doctor did you get? I got the cheapo one. Model number 350 (i think) Only pain $60 for it at Lowe's. But I love that thing. Works great. But I didn't know you could adjust the angle.
I have the xp. I don't think you can adjust it on the 350
my dad's a locksmith and we have had to resharpen hundreds of bit. he got a Darex drill sharpener that has a 'cartridge' that the bit mounts into. then it goes through the only motion that it can, which sharpens it perfectly. it uses a diamond grinding wheel and can do split point and just about everything you'd need to do. I guess you'd have to go to Darex.com or something. I think he paid about 600 for it. it's super nice.
I would stick with the std. 118 Deg and do the split point if possible.The split point will center the drill bit better.
Point angles are relative to heat coefficiants in production.
The broader point allows less heat over an effected area because there is lees area in contact.
A sharper point has longer cutting edges which means more area in contact.
Anything between 118*- and 135* is fine for general stuff.
I always grind a 135* angle for garage use. Because holding a hand-drill steady is impossible. The 135* angle could handle more abuse.
If you're drilling large holes with a pilot, buy a single flute chamferring tool. Drill your pilot and then chamfer the crap out the hole, atleast to hold captive the next size drill. If you pilot 1/4" and the next drill is 1/2" the big drill will chatter until it buries the tip, creating a triangular mouth.
Plus the chamferring tool is just good sense to have, nice clean holes, everybody wants them.
CrustyJeep said:
You don't need split points if you drill pilot holes like you're supposed to...
Your first step pilot drills could use them... But a split point on anything bigger than about 1/4" is just silly.
Split points work well depending on type of material being drilled,type of machinery being used.
On a rigid set up like on a vert. mill split points work well even up to 1/2".If you want an accurate hole(size,location)then you have to take other steps such as using a C'drill and or reamer.
In all the machine shops I've worked at,split point drill bits up to 1/2" are the norm.
Now if your drilling holes with a drill motor then stepping the drill sizes is a must and using split points after the pilot hole will not make any diff compared to a std. bit.
1 - 9 of 9 Posts
