1 - 16 of 16 Posts
Its going to vibrate like a SOB, if you angle at the t-case is 15 degrees the angle at the pinion needs to be at 15 degrees to cancel each other out.. So if you plan to keep your pinion pointed that much up you need a CV. And if you plan to angle the pinion down to match up the angle your going to be maxing out the u-joints so:
YOUR GOING TO NEED A CV SHAFT!!!
And the man to call can be found below in my sig line!
HTH
even the angles and replace u joints all the time or have a cv made at the t case side
okay, I have heard never know anyone that has one them selves, I will need a new spicer output for my rear yoke, to accept a cv right ? I have also be told that I can get one at a pick and pull off certian waggy's :confused: ............. thanks ..............ltr
Certain waggy fronts will have them as well as some older..later 60's and maybe some newer chevys. The waggy fronts have a real small OD on the shaft. Im sure there are more applications out there in the junkyard if you want to get one and cut it to fit.
You will need a new yoke for your t-case.
I simple cv shaft from jess might be better than getting a junkyard unit for the fact you can get anylength you want and you dont have to worry to much about breaking it.
I run a tom wood CV just because I bought it used for about 1/2 price.
the one ton i just got that im stealing the axles from for my jeep has a cv in the front driveshaft.. cant that be modified for use on the rear .. or not. im quessin it could be and ive not got it here to messure it till this weekend..
I have been running a cv out of a 78waggoneer front for 3 years now and have had no problems. I took the yoke from the transfer case front output at the same time and it fit my rear transfercase output (Dana 300). I shortened it myself and do not have any vibration. I run 4.88 gears with 35's and can cruse at 55.
the cv is probably the way to go
But Ithink you can rotate that rear up and you'll be fine
I found on my jeep (soa) that pointing the pinion right at the output and then going up 1or 2 degress (for axle wrap) you'll be just fine
my 2 cts.
jim
Discussion Starter · #15 ·
alright, through my increadble ablity to scroundge, I have found a cv rear shaft it is flange type, and use's the 1310 u-joint, what do I have to do make this work......................ltr
1 - 16 of 16 Posts
