1 - 2 of 2 Posts
I have some serious driveline vibs on my '97 ZJ... only asking for help because I have no idea what else to look for... heres how it goes.
  • Installed Teraflex S3Z (3.5") suspension, lower adjustable arms front and back, that is when the vibrations started.
  • Rebuilt the rear end (for something else), still have vibrations.
  • Removed front driveshaft, balanced and installed new-ujoints on the rear driveshaft, still have vibrations.
  • Replaced motor mounts, and tranny mount, still have vibrations.
  • Install 1.25" coil spacers, still have vibrations.
  • Install SYE, CV driveshaft, and upper adjustable arms... vibrations get a little better.
  • Replace pinion yoke, vibrations still there.
  • Replace CV driveshaft, doesn't help.
  • Replace tcase output shaft, vibrations get a little better.
  • Measure for runout, looks good.
I am stuck here.. I have no idea what else to look at. With the front driveshaft removed, I still get vibs at high RPMs, or when I reach 80mph.
What else could it possibly be? Tweaked unibody? Tweaked tranny output shaft? I am lost.
-gvb
on some of these /2003 rubicon's included:D -there's off-set /dog-leg- at the rear diff making angles fun to work with - the main complaint is 10 mpg and above uner acceleration only /mainly- real difficult to get rid of- hope this helps- Jesse
1 - 2 of 2 Posts
