1 - 4 of 4 Posts
What are the flange bolt diameters on the taco? Im looking for the f/r tcase and axle end flange bolt diameters. Also whats the diameter of the flange centering ring.
I think the flange centering ring is the same between the years (Taco and pre taco) but the diameter of the flange is different. I know inchworm has a flange that can be used with all the years of toyota driveshafts. Also all the flanges over the years can be interchanged.
I'll try to measure shit out when I get home later tonight from work.
That would be awesome man!! I need to order up some shafts for my truck and dont have access to it right now!
front output flange from a Tacoma
center hole 1.8" Diameter.
bolt holes diameter about .39inches
Diameter of the flange 4.035in
Rectangle for hole pattern.
about 2.375in apart center to center of the bolt
Rear output flange from a tacoma
Bolt hole diameter .39in
2.65in apart from center to center of the bolt
Diameter 4.465in
The measuring of the bolt distance was done by going around the outside ends of the rectangle bolt pattern. Also can't say they are perfect but was done with a micrometer.
1 - 4 of 4 Posts
