1 - 8 of 8 Posts
Does anyone have any suggestions for custom driveshaft work (building) in the W. MA area, Westfield, MA specifically? The closest I can find in the net search (phonebooks are all but useless these days :) ) is Custom Driveline in Keene, NH. No issue with them and helpful on the phone....just wondered if there was any place a bit more local. Thanks in advance.
Is Connecticut Driveshaft still in West Springfield?.....Do you just want to deal local or why not Jess at High Angle or Tom Woods?
Discussion Starter #3
CT Driveshaft, from what my guy tells me is in the process of moving (still local) and has been difficult to get a hold of. I will continue to pursue that option too.
Yes, considered (highly) Jess....Tom Woods....Reel and other "online" options. Would prefer local, but local is not the end all/be all. Setup with longer wheelbase, different driveline angles....double cardon to U-joint style (most likely)...blah blah....the usual and just want to make sure I get it right the 1st time out. I know Jess...Woods...Reel and etc have real good info on the sites and customer service is great so I may go that route.
I’ve used Mitchell Drivetrain in Shrewsbury and would use them again no question, I also used high angle as well, same deal I’d use them again.
Discussion Starter #5
Forgot about them! I had them shorten/respline some D60 axle shafts. Thanks!!
The shop in CT I was thinking of...that moved was Advanced Drivshaft in (I think) S. Windsor.....
I know I'm late to the party here, but Todd at Endangered Species Jeep would know where to send you. His shop is in Holyoke I believe.
Just had a CV issue and brought it to Chris at CT Driveshaft in East Hartford. Fast and inexpensive fix. Nice family and will use them again...
Discussion Starter #8
I’ve used Mitchell Drivetrain in Shrewsbury.
Yes, went back to Mitchell D/L. and all is good for now. Thanks, I am ashamed after having axles cut/splined by them I totally dropped them from memory for driveshaft work
1 - 8 of 8 Posts
