1 - 13 of 13 Posts
every inch of belly clearance is worth 2 inches of tire size!!!!!!!!!!run 35's and raise the drivetrain 2 inches(actually 5" if you get a low profile crossmember) and its like running a 45 inch tire, with respect to belly clearance...
Originally posted by toy 4 rox:
<STRONG>what benifits is there?[why do it ] and what is involved? <IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0"></STRONG>
What's up vincent! I a drivetrain lift over the summer and must say that it came out sweet! I used Roger's engine lift blocks, built a new xmember, torched out the horsecollar xmember, and also lifted the gas tank 2". It's almost completely smooth and my xfer case crossmember is really beefy and very smooth should I drag it over the rocks! There are quite a few little things like messing witht the fuel lines (or at least I did) but the result is well worth it. I say go for it. Your trucks coming right along since we were on the con last summer. Take it easy man.
Originally posted by fmf:
<STRONG>What's up vincent! I a drivetrain lift over the summer and must say that it came out sweet! I used Roger's engine lift blocks, built a new xmember, torched out the horsecollar xmember, and also lifted the gas tank 2". It's almost completely smooth and my xfer case crossmember is really beefy and very smooth should I drag it over the rocks! There are quite a few little things like messing witht the fuel lines (or at least I did) but the result is well worth it. I say go for it. Your trucks coming right along since we were on the con last summer. Take it easy man.</STRONG>
you got rid of your horsecollar too?? mines gone(in the center) but with the added rigidity of rocksliders and the dual case xmember(sits back a bit farther) i have no plans to change this or worry about frame flex...u??
Originally posted by paul robert ryun: MTN GOAT:
<STRONG>you got rid of your horsecollar too?? mines gone(in the center) but with the added rigidity of rocksliders and the dual case xmember(sits back a bit farther) i have no plans to change this or worry about frame flex...u??</STRONG>
No, I still have it, but it's moved up 2" now. I knew that I was going to need a cv shaft in the rear so I moved it up as much as I could, did the rear gastank mount to match but I still had to clearance it quite a bit to prevent the cv shaft from rubbing. I also have rock sliders and a beefy xfer case crossmember so I'm not really worried about it. The truck's not a daily driver either so I'm not worried about it. <IMG SRC="smilies/biggrin.gif" border="0">
<STRONG>thanks tim.are you going to put pix on your site i looked but non found intrested in the xmember and the gas tank and the coller fix.</STRONG>
I have pictures of all that on my page (posted earlier in this thread):
Drivetrain lift with pix
Discussion Starter · #12 ·
Originally posted by 4CrawlR:
<STRONG>I have pictures of all that on my page (posted earlier in this thread):
Drivetrain lift with pix</STRONG>
i did go to your site and it is very therow .lots of good info and pics thanks
call Kongs Offroad Center he just did a sweet 3" powertrain lift with a new smooth cross member, raised the fuel tanl 3" and modifyed the horse collar. it turned sweet!
everything is flush with the frame, thats with dual cases!
their number is 602-944-2411 ask for mark only
i think he is going to start manufacturing the flush skid-crossmember
CALL HIM he also has a digital camers at the shop he can send pics <IMG SRC="smilies/smile.gif" border="0"> <IMG SRC="smilies/eek.gif" border="0">
1 - 13 of 13 Posts
