1 - 4 of 4 Posts
If your steering geometry is set up right with the tie rod on top of the knuckles (for clearance and to compensate for lift)should you use I drop pitman arm or the stock one?
I have both to use, doing a hydro assist, tie rod on top of knuckle setup on a coil sprung 44 w.trac bar (I know I gotta make the tie rod and trac bar parallel for bumpsteer)
1 - 4 of 4 Posts
