1 - 20 of 36 Posts
I looking to run dual t-cases on a samurai. Are the toy t-cases the best to use, with the adapter from OTT.
Chubby Chaser
You should ask this question in the Sammi Forum. Fatkid (the moderator there) just did the same thing you're talkin about;)
Discussion Starter · #10 ·
is the ringer compatible with the 1.3l? all the searches I have read are just saying the 1.6.
Discussion Starter · #14 ·
yeah, i got a coulple of toy t-cases. probably go with the 4.70 gears in the rear case and run stock up front.
Discussion Starter · #16 ·
probably finish putting my locker in the d60 tonight. just going to stick with the 4.56 f&r and hopefully the t-cases will make up the difference.
With 4.56's, you run the front tcase in low all the time - gives you the same reduction that a stock sammy case does then.
Are you moving the rear axle? If you can move it about 10", your good to go then. The toy tcase output for the rear is high up, which means you need a little more wheelbase to deal with driveshaft angle.
Discussion Starter · #18 ·
yeah, i am stretching it out, shooting for 100 - 105" wb. Running a d60 front and gm14b in the rear. probably going with 39.5x15.5x16.5 TSL's
with dual toy cases, a 2.28 in the front case a 4.7 in the rear he will have enough torque multiplication to break a dana 60 if he tries. even with a 1.3, but i bet he goes to a 4.3 and a auto later on.
1 - 20 of 36 Posts
