1 - 15 of 15 Posts
I have acquired both of my propane tanks(43 lbs a piece) and I'm getting them mounted up as soon as the engine is done. I'm wondering if I can put a fuel guage on the tanks and if I can also put a switch between em. Like what is in a ford truck w/ dual tanks. A switch so that I can switch between the 2. Please let me know so I can figure out my wiring and figure some other things out.
yea you can put a "switch" between tehm but its probably easier to use a mechanical switch IE valve that will allow you to switch between them
Of the customers i fill for propane, they all run on km's. Only 2 of the 20 or so regular customers have guages, but those 2 trucks came factory with propane rather than a conversion after it rolled off the line. By running off km's, i mean that they know their tank will drive em 1100k, so around 900 they get it filled. Are you mounting the tanks underneath the rockers
forklift tanks or automotive?
you can run the factory guage switch
to have both tanks hooked up legally here you have to run a backcheck valve between them, you need a T fitting anyway so this isnt a big deal.
I just open one tank at a time.
run it til it is dry then open the second one.
MuddinXJ said:
they are 43.5 lb forklift tanks. I am mounting them both in the rear of the YJ.
There should be guages right on the tanks
If you've got the 43lb tanks, you won't need more than one in a day... Most people run the 33# tanks and get a day out of 'em.
Mine are run into a T, but if for whatever strange reason I run out during the day, I just close one and open the other... or if I plan ahead, it'll run for a few minutes on what's in the lines.
clear your trip meter, fill tank drive tank till empty, look at trip meter......are you still with us?
Discussion Starter #14
lol. yeah I wasn't sure how long because this is gona be a commuter for me to and from school and a trail rig also so I was just wondering.
on another note I may be selling the tanks because I had a nicely masaged 302 appear in my garage
And that applies off road, when you can travel 8 miles and burn 7 gallons? Didn't think so.
I 'spose you could apply some of those temperature sensitive stickers to the tanks like on a BBQ grill tank... :rolleyes:
Just get multiple tanks, and change them once a day. ;) Just make sure your fill place charges you by the pound, not by the tank fill. (They do this alot for fork tanks)
1 - 15 of 15 Posts
