1 - 20 of 30 Posts
Can someone tell me the difference between a mid 90's, ball joint, front Dana 60 out of a dually F350 versus a single rear wheel F350? Obviously the hubs are different but what about the knuckles, spindles, axles, and housing?
Thanks,
Pete
The hubs are the only difference.
How are the hubs different?
Bad choice of words on my part. I meant the wheel adaptors for mounting dually style front wheels. Not the locking hubs. oops. <IMG SRC="smilies/blush2.gif" border="0">
When we say hubs I bet it is the bearing hub's not locking hub's. On some older 60's the locking hubs were also different. I have converted a dully to single and I only changed the bearing hub and rotor.
dug up this old thread during my search. Iwas lucky enough to finda a HP dana 60. The only problem is that it has dually front hubs. how hard is it to swa it over to SRW hubs?? and what all do I need to change?? TIA WIll
I just bought a 97 Front D60 DRW setup, and all I had to do was remove the dually adaptor and re-press in the wheel studs. Not that hard. The spindle, knuckle, and everything else including the wheel bearing hub were the same. It is kinda just like a big steel wheel spacer.
87-94 F250 D50 TTB hubs also work. Actually, 80-97 F250 may work, but my searches have shown that the bearing part numbers vary on the early and late ones... 87-94 is a sure thing.
I bought a DRW 86 D60. I'm using a 78 hub and a F250 hub with some 2wd F250 calipers and the DRW rotors.
The wheel studs are different also, FWIW.
I've never seen any that were actually adapters... got any pics?
1 - 20 of 30 Posts
