1 - 13 of 13 Posts
early 90's or mid-late 80's rear. what did they usually come with, a 60 or 70? i searched, couldn't find anything on the vans, just f-350's. thanks.
probably a 10.25 Sterling...might be a D70 though, but my bet would be on a sterling.
HTH
Later
Dan
oddly enough an E-350 will have a D-70 in all likelyhood. The sterling seemed to be only in use in the F-series. I've yet to see anything other than a Dana/spicer under a 3/4 or higher Van.
yeah, i'm pretty sure the 94 E-250 i was driving at work had a D-60.
I have never seen a van have sterling. It could be a D 61:( watch out for those. If its a 350 it prolly has the 70!
its definetly not a sterling, i know what those look like. i just couldn't decide if it was a 60 or a 70. i can't read the numbers on the housing, how else will i know for sure?
3.5" tubes = Dana 61 or 70
35 spline shafts = Dana 70
Mine says '70' in the webbing.. no chance it's a 61 is there? I'm going to fix it up but I'll stop now if it's a 61 :)
Thanks
Don't think so. pretty sure mine said 61 in small letters (1/2" tall?).
pull a shaft to make sure.
Sadly I had it pulled the other day and didn't count the splines. It did look roughly like a 35 would look though. I think I'm safe.
I think I'm gonna do a disc brake conversion on it.. it'll cost less than fixing hte stock brakes.
Discussion Starter · #13 ·
broke down and pulled a shaft, 35 spline. guess i got me a 70.
1 - 13 of 13 Posts
