1 - 1 of 1 Posts
90 f250 7.3 4x4 . If I shift into reverse. it engages, shift into 2nd or 1st it engages , put the selector on D and nothing happens . This is while stopped , I do not know if it will shift into 3rd / 4th if I manually shift it once its moving , I am just now putting the truck back together and trying to get it on the road .Mlps is aligned .. I've read about faulty mlps shifting out of gear while driving because it thinks you shifted into neutral , but would it cause my problem ? It's as if I have P,R,N,N,2nd,1st . The trans sat for over a year , maybe something is just stuck ? When you put the selector in D does it not start out in 1st ? This is what I don't understand . If it engages in 1st why won't it engage into 1st when shifted into D ..
The tach does not work . I just bought a new tach sensor from Ford hoping it would fix the problem , still no tach . I know without a tach the e4od won't operate correctly , but does the actual tach gauge have to work , or can it get the signal from the tach sensor even if the tach gauge is faulty .. ?
Any help is greatly appreciated . I am without a vehicle until this is fixed .
1 - 1 of 1 Posts
