1 - 19 of 19 Posts
None of the EB 9"s came with anything but 28 splines from the factory. I have read some stuff about 77's having 31 splines, but I've never seen anything concrete to confirm that.
........so brick wall is wrong?:flipoff2: why would he post that:confused:
Yep, all EB"s are 28 spline stock. I have never seen a 77 with 31 splines, but I have heard rumors.
Some are big bearing axles, some are small. Bigbearings canbe easily upgraded to 31/33/35 spline. 35 spline requires a different drop inwith bigger carrier bearings.
No first hand info, but I thought this was right.
I've heard rumors that the Stroppe Baja Broncos had 31 spline axles but, those were only rumors . Other than that, Early Broncos had only 28 spline axles be it small or big bearing.:(
I offer my humblest apologies for incorrect information. Dyslexia has kicked in yet again I read 72 and earlier 31 spline axles have the ability to be shortened and my mind read 72 Bronco blah, blah 31 spline blah, blah.:flipoff2: My head hurts from working on my own 9"...
:D ;) ;) ;) ;)
There are actual 3 sizes of bearings the largest of which(325) is required for 35 spline unless you go with a spool in which case a (306) bearing center will work. I think the third size was like (297) not for sure on that.
How do you tell which bearing size the axle has without tearing it down? I don't feel like ripping apart every axle at the pick and pull to measure bearings.
pretty much everything that is 28 spline is the smallest bearing and every thing that is 31 spline is 306 I beleive the 325s may not have come in anything unless there is an actual stock 35 spline 9" application.People tend to make the mistake of calling a 306 a big bearing 9" which is just not the case.
There are a few other ways to tell what size the bearing is. The flange on the housing where the axle retaining bolts go thru is shaped differently on a big vs a small. Also the small bearing retaining bolts are 3/8 while BB is 1/2. The other bearing size which is sometimes called the torino bearing is very hard to tell it is a medium bearing size and looks like a BB. I had a torino bearing size in my '75 that was the original factory rear. Regardless of bearing size they will all be 28 spline.
1 - 19 of 19 Posts
